heath.orrell
#1 Posted : Tuesday, April 8, 2014 8:14:52 AM(UTC)
heath.orrell
My GE Side-x-Side refrigerator (model GSS25WSTFSS) control display ASM is no longer working. I was able to see the temperature show on the display when I would depress the switch to dispense water, but then it would go dark and no water or ice would come out. I could change the temperature. I tried unplugging the refrigerator and resetting it, but when I plugged it back in, the display went dark and no buttons work and no lights on the display come on.
I checked the base of the freezer door, and don't see any issues there. I did notice a white wire coming from the sheathing from the freezer door that was not connected to the plastic connector, but it was does not look like it was connected. There is a black and blue wire connected to the housing from that sheathing, and the other end of the connector contains a black, blue and red wire that head back under the unit.
Is the display board the culprit? I took it off of the freezer door and disconnected and reconnected the wiring to no avail.
Please advise.
Thanks.
Heath
#2 Posted : Thursday, April 10, 2014 2:27:35 AM(UTC)
I would replace the motherboard, the display boards rarely fail, but the display gets power and signals from the motherboard
