the original part located on the compressor is a 1) overload relay attaches to the top prong of the 3 prong pin connector. attached is (1) black wire and (1) blue wire. the second part is a 2) start relay attaches to the (2) bottom pins on the 3 pin connector. attached is (1) black wire and (1) white wire. the replacement part combines the DUAL duty into one unit and has hookups for two wires and came with NO INSTRUCTIONS. HOW DO I HOOK THIS REPLACEMENT UNIT INTO THE SYSTEM. I HAVE CONTACTED SEARS PARTS REPS AND ALL THEY WANT TO DO IS SEND A REP OUT. NO PROBLEM TAKING MY MONEY FOR THE PART BUT ARE UNWILLING TO HELP SOLVE MY PROBLEM. I KNOW THIS IS NOT A BIG PROBLEM AND I'M NOT THE FIRST TO ENCOUNTER THIS .........NEED HELP!:confused:
I have a similar problem. Did you ever find an answer for this.
The new part just plugs in to the 3 compressor pins, the two male spade terminals get the fridg power wires and the other two, the run capacitor. Polarity insensitive.
