zephlew
#1 Posted : Tuesday, March 25, 2014 6:00:09 PM(UTC)
zephlew
Hello-
Is there a way to test a water inlet valve? My water dispenser is not working but ice maker does.
-door line not frozen
I replaced thsi inlet valve a year ago but don't remember how I came to the conclusion that it was bad.
mr_mjsjr
#2 Posted : Wednesday, March 26, 2014 4:34:55 PM(UTC)
mr_mjsjr
you can verify that you are getting 120V to the valve/solenoid. if so you can also, ohm out the valve. if you are getting 120V and the the valve ohms open you can bet it is bad.
