My ice maker keeps freezing up before the water comes down that white shoot. I have fixed it twice and i am missing a part possibly? It is frozen if i take the ice maker off and that white hole is frozen as well. Temp is fine. Any suggestions? Ty
Here are your parts Parts for Whirlpool ED5PVEXWS00 Refrigerator - AppliancePartsPros.comI cannot say if you are missing a part, take a look at the ice maker section 12. Could be a bad water valve. Re: it is not closing fast enough and allows a drop or two through this then drips and freezes causing problems. You said the freezer temperature is OK, have you measured it with a thermometer? |
THIS FORUM IS DEAD!!!!!!! |
Where is section 12? Temp was 38. Ty
Section 12 Icemaker Parts in in the parts breakdowns (the link I gave).
Something is very weird . At 38 degrees everything would melt is the freezer. |
