I have a whirlpool gas dryer that will not heat. The igniter turns on and lights the gas for a few seconds and then the flame goes out. A few minutes later the same happens. I replaced the coils but have the same issue. I'm wondering if it's likely that the Internal-Bias Thermistor is bad and turning the gas off?
