Hello, my ice dispenser will only dispense crushed ice when I set it to crushed. When I set it to cube no ice comes out but I do hear a click nose near the bottom panel.
I opened the freezer door and tape the latch down then I removed the ice bin. I switched it to crushed mode and held down the dispense button and I can see the shaft rotate. When I switch it to cube and hold down the dispense button the shaft does not rotate.
Does the motor rotate one direction for crushed and the other direction for cube?
I'm not sure how to diagnose my ice dispensing problem.
All help is greatly appreciated!
