I own a frigidaire washer/dryer combo. The dryer itself is fine, it will run and everything. The washer, however will not run. The dial on the control interface will not make a noise (the dryer will). I have opened up the front lower panel to access the washer internals. Inside the black control module there is a green LED that flashes 4 times, then once. Any help would be greatly appreciated.
