My dishwasher is about 8 yrs old. Just recently the top and bottom sprayers are spraying water but not spinning. They have free movement. When I put it in a rinse cycle, close the door, then open the door after it has ran for a minute the spray wands are in the same position but water is coming out of the holes. Any way to run it with door open to see what is going on. Also the soap dispenser is opening but the soap just runs down the door and doesnt get spread around. The dishes are not getting clean at all. Any suggestions.
THIS FORUM IS DEAD!!!!!!! |
