Steve K.
#1 Posted : Tuesday, December 10, 2013 9:13:03 AM(UTC)
Steve K.
Unit is combined stack unit, apartment-size, possibly less than 10 years old judging by appearance and conditon, but age unknown. Washer fills with water and will agitate but will not drain at end of wash cycle.
Faint clicking can be heard from switch. If switch is manually advanced to dot position in rinse cycle, agitation will resume, but washer will still not drain at end of rinse cycle.
Should I replace pump, or is problem likely in switch or other control?
Thanks for the help.
fairbank56
#2 Posted : Tuesday, December 10, 2013 10:27:14 AM(UTC)
fairbank56
Groups: Expert
That model is over 20 years old. Does motor run when in drain mode? Does it spin?
Eric
Steve K.
#3 Posted : Wednesday, December 11, 2013 6:23:58 AM(UTC)
Steve K.
Thanks much for the reply. Bizarre as it seems, the washer now drains but will not spin or spray rinse. I did not do any maintenance or make any adjustments.
Any advice?
Thanks again.
fairbank56
#4 Posted : Wednesday, December 11, 2013 10:36:04 AM(UTC)
fairbank56
Groups: Expert
Drive motor must pause for a few seconds after the 2 minute drain period to shift gearcase out of neutral. Is it doing that? If not, open lid for a few seconds to pause motor and close again. Does it start spinning? Remove front panel and observe clutch hub on top of gearcase during spin. Is the clutch hub spinning?
Eric
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Frigidaire washer not draining, no high speed spin (Washer Repair)
by Stheemka 3/24/2020 6:39:56 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Whirlpool washer not draining or going into spin (Washer Repair)
by snugent 9/8/2015 4:30:21 PM(UTC)
Kenmore Washer not draining after rinse cycle (Washer Repair)
by CRrie 8/11/2015 3:24:34 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
