martinoleonardo
#1 Posted : Wednesday, October 14, 2009 7:24:36 AM(UTC)
martinoleonardo
Hi, I've replaced the temperature sensor but it has not completely solved the problem of the oven not keeping the correct temperature. I read somewhere to also replace the oven ignitor. Do I have to splice the wires together on this model?
After I put the new sensor on, I discovered an access panel at back of the stove where i could have just plugged the new one in instead of having to strip very thin wires.
Is there any access to where the new ignitor plugs in, or do I have to strip the wires and connect them with the ceramic connectors?
