All functions on the control panel work except that the unit will not heat the food or items when placed in the microwave. Tried all functions and timings to make sure it was not a control board issue, comes on but still does not cook. Turntable moves and the fans and other functions work, just no heat. If the Magnetron is bad, and I assume it probably is, should I replace the diode at the same time? Thanks RTR
