New igniters in oven & broiler. New dual gas valve. 3.2 amps draw & the valve does not open to ether application. Yes I do have gas (all 4 range burners work OK). I have left the igniter on for 30 min.The valve heats up but does not open ????? Help. Red wires from the igniters are at the lower connections at the gas valve.
