I have an old Kenmore GSD940 dishwasher. The soap dispenser lid will not lock/latch closed after I add soap. I purchased and installed the repair parts from AppliancePartsPros.com. Part numbers:WD16X313 Shaft detergent cup, WD16X297 Detergent Cup Cover and WD16X10011 Latch detergent cup. The cup cover is slightly different than the original in that it does not have a rubber o-ring gasket and also does not cover the entire soap area or fit snuggly.
What else could be wrong? Any help would be much appreciated or else I will need to purchase a new dishwasher. Thank you in advance.
Jessica Z.
