Farmer85
#1 Posted : Monday, October 7, 2013 1:37:56 AM(UTC)
Farmer85
Hello, I'm still having problems with gas dryer not heating up. No nuetral to bottom gas solenoid valve is what I believe is wrong. I've tested everything over and over. Replaced the control boards. Still nothing. The only thing I can come up with is maybe my cent switch is not closing contacts. I took it apart and contacts are good. The red lever looked slightly wore, is it possible that the contacts would ohm out good at idle but not work right? I thought once the cent switch opened up the lever just hung there and would spring return to close the contacts for the gas ckt? This is the only thing left that I'm not sure about. I have already spent 250 or so on control boards. Now it may need a motor but I need help testing this cent switch to make sure. Oh and by the way the dryer works fine except no gas.
