The washer will go through the wash cycle. It agitates and spins, but when it gets to the rinse cycle it fills with water and stops. It will not drain the water, or spin. I can hear a hum, then it shuts off. It has an error message OE. I checked in the book and it means something could be obstructing the pump. We checked the hoses and cleaned the pump filter. That didn't fix it. We replaced the door latch and it still won't work on the spin cycle. Any suggestions?? I'm at a loss on what to do!
Sounds like a drain pump circuitry problem............check the drain pump for 120v when it's in drain cycle if you have 120v going to it and the water isn't pumping you've got a bad pump..........if there isn't 120v going to the drain pump during draining you have a main control or harness connection issue. Here's a video to help http://www.youtube.com/watch?v=lF9pbRnpO98
