Won't start, start button will not light up all other buttons light up except pots n pans , when that is pushed drain lights up and comes on. When drain button is pushed it cycles drain no water in it though as to it won't start. Ran fine yesterday clean dishes unloaded then loaded it no starty, must have power for lights and drain to work . Control panel? Thanx
