The door latch intermittently unlocks. When I shut the door, the solenoid latches, Door Closed LED on for about 1.5 seconds, then the latch releases. Sometimes I'll get an OD (open door) error code.
It seems to be happening more frequently.
Adjust the strike in the top of the dishwasher that the latch goes onto if it's metal and if not just replace the door latch assembly and check the door make sure it's aligned right they can get messed up from people leaning on the doors.
