drericdc
#1 Posted : Thursday, October 8, 2009 4:55:21 AM(UTC)
drericdc
Ice builds on floor of freezer then water spills on to floor. Freezer on bottom (pull out draw). Pulled away from wall vaccumed, replaced broken rear wheel with 1/4 wood shim. Looked at drain tube after removing rear panel seemed ok. Still leaks
applianceman
#2 Posted : Thursday, October 8, 2009 10:49:04 AM(UTC)
applianceman
You are going to have to take the cover off the evaporator and clean all the ice off the top of the drain hold under the coils. The best way to do this is to use a turkey baser to force hot water down the drain until it is free.
If the drain is clear the leak may have something to do with the icemaker (if equipped). Hope this helps!
Refrigerator repair guide
Freezer ice on floor build up (Refrigerator & Freezer Repair)
by drericdc 10/8/2009 5:01:18 AM(UTC)
