Defrost Cycle not working. Freeze coils ice up stopping airflow. I have Checked the Bimetl Def and the heater coil - both are working. Not yet replaced the Circulating Board as it's over $200. Is there anything else to check. Drainage? Also, what line is the bimetl def supposed to be clipped to? - does it matter? Thanks, John
