I have a Thermador PRG304US range. The oven gas sputters intermittently. The igniter does glow bright yellow. I did check the dual gas safety valve: 1.1 ohms resistance and 118 to120 vac across the valve. The valve also has no continuity from the valve body to any of the valve leads. I assume to problem is either the igniter or the dual gas safety valve? Any help would be appreciated.
