The washer DOES agitate and DOES drain, however, it DOES NOT SPIN to remove the excess water from clothes. I did turn the agitator counterclockwise and this did initiate the spin cycle and it did remove the water from the clothes. It it NOT making any loud or weird noises. What needs to be repaired? Thank you.
Can you hear the motor running during the spin cycle when the tub does not spin?
Originally Posted by: ApplianceJunk Can you hear the motor running during the spin cycle when the tub does not spin? it's a humming noise
Originally Posted by: funtime it's a humming noise It makes a humming noise when it is spinning.
