My machine will fill properly when the temp setting is on TAP. On cold warm or hot. The water skeets out then quick pause then skeet. It continues this until filled then washes properly. then rinses the same as skeet mode. Also my lines fill like they are pulling on air. I bleed my Hot water tank no air. Water in house is fine unless the washing machine is on the Skeet cycle. Then all water in house has a constant pressure problem. Please help anyone!! And correction. the model is WTW5800S
