Problem is the compactor has stopped compacting. The motor runs, the ram moves up and down but does not apply sufficient pressure to the material in the drawer before reversing. Is there a pressure switch or a limit switch on the motor that needs to be replaced or is it an "all in one" motor unit. I have had the machine covers off and am familiar with the motor, gear and ram mechanisms. Any help would be appreciated.
