Hello,
My washer is leaking from the very center of the machine.
I have parts for replacing the R9900457, & R9900189.
I am having trouble getting the bolts holding the inner tub out and I also notice the agitator dogs are broken and will not move. All the videos show a different type of agitator dog setup. So far mine in this order: agitator(one piece) then the bell drive. Next I see the top of the seal the agitator dogs then the inner tub hub. I believe the bolts for the inner tub need to go counter clockwise to remove. I have sprayed with WD-40 and left overnight no budging. Any suggestions?
As I said before the videos are for a different type of agitator dogs. Do you know the part number for the dogs and the ring that they are connected too? Because from what I can see it is some sort of ring. Do I remove the agitator dogs/ring before removing the inner tub or after?
I am getting frustrated because everything I look at doesn't seem to match with what my machine looks like. I need to get this fixed my washing is piling up and I have other things need fixing.:(
Any help would be greatly appreciated.
Glenda
Glenda I just used an air tool to remove mine, they were very tight.
