Hey gang pulling my hair out with this combo washer /Dryer unit. Started with everything running just no heat so I changed the gas coils, it would run one cycle then just the ignitor would stay on. I had the panel off the front to watch the burner and a wire came off the timer and arc'd and tripped the breaker, after that the timer wouldn't move, so I ordered another timer, installed it and it doesn't move arrggg. The dryer still turns but now no igniter, i checked the ignitor for continuity and it has a value, the flame sensor shows 0 which is right I think, i can't find a thermal fuse or limit or Thermostat anywhere and i don't have the schematics, any body send me in the right direction, thanks gang
