bobkat
#1 Posted : Sunday, October 4, 2009 12:34:08 PM(UTC)
bobkat
Last night the spin cycle seemed off balanced then it was quite got up this morning and it didnt spin the clothes out and now it makes a humming noise, read that it could be the coupler, what is that and where is it on the washer and where do you get the part?
:eek:
sidfink43
#2 Posted : Monday, October 5, 2009 8:43:18 AM(UTC)
sidfink43
Ok, start a cycle and see if it will agitate. If it will not, then move the timer to the end of the wash cycle to drain the machine and then you are ready to check the coupling.
Here is a video which will show you how and where it is.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Note: Do not take off the pump, just tie it off to the left (If you do decide to take it off you will see why we say don't)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
Sears Kenmore 70 Series . Model 110-82870120 (Washer Repair)
by washerTed 10/2/2023 6:42:28 AM(UTC)
Top load Kenmore 70 pn Vibration only after spinning cycle (Washer Repair)
by jacob3204 2/10/2023 8:54:01 PM(UTC)
Kenmore 70 series not starting after breaker tripping (Dryer Repair)
by thenameskilo 4/7/2021 10:25:38 PM(UTC)
Kenmore 70 series not starting (Dryer Repair)
by thenameskilo 4/7/2021 10:24:08 PM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
Kenmore 70413415 (Refrigerator & Freezer Repair)
by dcmdpilot 3/4/2020 4:29:14 AM(UTC)
kenmore 70 series problem (Washer Repair)
by richham 6/13/2015 4:08:08 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Kenmore 70 series washer doesn't work (Washer Repair)
by kman6206 1/17/2015 3:38:49 AM(UTC)
Kenmore 70 series (Washer Repair)
by D.mccauslin 1/7/2015 6:20:04 PM(UTC)
kenmore 70 series not spinning unless manually put to spin (Washer Repair)
by adm388 8/13/2014 8:58:14 PM(UTC)
Kenmore 70 dryer panel settings not working (Dryer Repair)
by dlrowe 6/20/2014 11:03:42 AM(UTC)
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
