The oven door will not stay closed completely. It opens slightly to a position just enough for the oven light to stay on at all time. I can push it closed further, but it will re-open to a slightly open position. I cannot see that there is anything holding it open. Any thoughts?
Possible the problem is a bad door hinge or both of them. Unfortunately the right hand side door hinge is no longer available.
