I have dealing with the ice maker issue for a while now. It works Ok for a few days then starts to overflow sending icicles over the sides. I replaced the Dual valve in April of '11 worked fine after that Then the Motor assembly a few weeks ago. I have tried adjusting the timer with some results. The problem is intermittent, Works OK for a few days then starts up again. But as I was sitting here typing I just heard the fill valve open for about 2 seconds, stop then immediately open again for a couple more seconds. I looked at it and it had water dripping for the tray. This is the first time I caught this do it. Is it the valve again??
