roy bradshaw
#1 Posted : Friday, March 1, 2013 3:20:57 PM(UTC)
roy bradshaw
i would like to know how to remove that speed control knob out of the control board of a kenmore elite washing machine without breaking it,,thanks, Roy
Joe / APP Team
#2 Posted : Friday, March 1, 2013 4:08:18 PM(UTC)
Joe / APP Team
Roy, Most, if not all, control knobs are "slip on" type fits. They can be hard to pull off especially on older units, so you need to be careful.
fairbank56
#3 Posted : Friday, March 1, 2013 4:08:55 PM(UTC)
fairbank56
Groups: Expert
The knob should just pull straight off. To remove the switch, lift up on the locking tab and rotate the switch about 30° and pull out.
Eric
roy bradshaw
#4 Posted : Friday, March 1, 2013 11:45:44 PM(UTC)
roy bradshaw
Great info, no problem pulling knob off, now I just got to remove switch and I believe I can handle that. Thanks very much.:)
Joe / APP Team
#5 Posted : Saturday, March 2, 2013 8:48:12 AM(UTC)
Joe / APP Team
Roy, You're welcome. You didn't supply a model number, but as Fairbanks posted, Once you get into the control console, release the locking tab and turn the switch assembly counter clockwise to remove it. Just make sure you remove power to the washer before you do anything. Thanks Again
roy bradshaw
#6 Posted : Monday, March 4, 2013 3:11:46 PM(UTC)
roy bradshaw
Yes sir, i asked about this knob switch because the machine will only operate on the heavy duty speed, if you move it to regular the washer just makes a skipping tap noise and nothing works. I have not tried it on the delicate or handwash/casual speeds. This is a kenmore 80 series mod 110.20852991. I was just wondering if the switch is my problem.? what do you think?
roy bradshaw
#7 Posted : Monday, March 4, 2013 3:18:52 PM(UTC)
roy bradshaw
thanks:) I hope this is enough info.
fairbank56
#8 Posted : Monday, March 4, 2013 4:17:12 PM(UTC)
fairbank56
Groups: Expert
It could be the speed switch, the motor, or connection issue. Check the 2-wire motor connection at the motor. This motor has the standard 10-pin connector as well as the extra 2-pin for the two low speeds.
Eric
