Just got my ATC switch. Watch videos for replacement. Went to machine. Removed 2 sheet metal screws in back top. Panel doesn't budge! I have tried push, pulling lift & swearing - all to no avail. One thread said there were three screws. The only other screw on back near the top is a machine screw with a grounding wire attached. I don't think that's it and but I tried anyway. No luck. Help please.
Thank you! The putty knife did the trick. All set now.
