I have the hinge supports - but is there a way to install them without removing the entire oven-warming drawer-microwave stack? Q&A advised that I could just pull it out a few inches; but the screws holding the supports go in from the front - and are blocked by the flanges of the oven's interior sheet metal. Is there a way to remove the whole oven liner without completely removing the assembly?
A local Thermador service person advised that in his long experience, the hinges solved the problem of the door not quite closing - even though swapping doors didn't fix it. It turns out the newer hinges are much, much more powerful than the 10-year-old originals and do fix it. Originally Posted by: jonwells I have the hinge supports - but is there a way to install them without removing the entire oven-warming drawer-microwave stack? Q&A advised that I could just pull it out a few inches; but the screws holding the supports go in from the front - and are blocked by the flanges of the oven's interior sheet metal. Is there a way to remove the whole oven liner without completely removing the assembly?
Groups: APP Team
