anitabird
#1 Posted : Tuesday, January 8, 2013 12:38:12 PM(UTC)
anitabird
Wash machine will not quit filling with water. Therefore wont aggitate. will drain and spin. what could be the problem
fairbank56
#2 Posted : Tuesday, January 8, 2013 4:43:21 PM(UTC)
fairbank56
Groups: Expert
Remove the front panel by inserting a putty knife into the top groove of the panel in line with the lid opening on each side to release the clips. Tilt panel outwards and lift from cabinet. Check the air dome and air hose on lower left side of the tub for gunk. Pull the hose off the air dome bib and make sure its clean. If there is gunk in the air dome, use a turkey baster with hot soapy water to try and flush it out. The air dome is welded to the tub and is not removable. If there is no gunk buildup, check the hose for cracks/splits all the way up to the pressure switch behind the control panel. If all is ok, you need to check the pressure switch.
Eric
anitabird
#3 Posted : Thursday, January 10, 2013 11:42:09 AM(UTC)
anitabird
Eric
Tried what yousaid but looks like you can take off the silver platet foom behind control panel. see no clips..
fairbank56
#4 Posted : Thursday, January 10, 2013 12:31:11 PM(UTC)
fairbank56
Groups: Expert
GE washer Taking it apart - YouTube
Advance to 1:47 into video for front panel removal instructions.
Eric
David K
#5 Posted : Monday, January 21, 2013 10:10:01 PM(UTC)
David K
This is what I did... I did this last 2 years in a row. I have slightly different problem. I just cleanned out the hose a about a month but still did not work... why? the reservoir had stuff - gunk in it.
I did the following:
1. Loosen the gunk inside the reservoir. I got a coil. I shaped it in zigzag pattern and hooked it up with my drill. I put the zigzag patterned coil end into the reservoir and ran the drill for a few 10 -30 seconds in slow speed. I tried to loosen it at different depth.
2. Wash away the loose gunk by letting the water rise up in the washing machine tub. You can watch the water level rise. Stop when it reaches the top of the reservoir. Then unplug the hose. Plug in your own hose to the reservoir and blow air fast and hard into it. It will blow out the losened gunk into the washer tub. Do it several times. Then put back the hose and spin out the water.
3. Repeat above 1&2, if necessary. I did 3x.
4. I also cleaned the hose to the reservoir tube.
Good luck. Hope it is helpful.
GE Washing Machine Drips When Off (Washer Repair)
by kevin1boyd 5/7/2017 5:48:33 AM(UTC)
GE Washing Machine freezes and locks up (Washer Repair)
by Swilly 8/24/2016 1:39:40 PM(UTC)
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
ge washing machine help (Washer Repair)
by dnpro02 3/19/2015 7:57:02 PM(UTC)
GE Washing Machine Making Crazy Noise and Electrical Smell (Washer Repair)
by TripleDigitRide 6/21/2014 8:05:46 AM(UTC)
GE Washing machine is overflowing on super setting only (Washer Repair)
by Ctomanec 3/29/2014 9:53:09 AM(UTC)
Ge Washing Machine won't work. (Washer Repair)
by schristensen22 7/15/2013 5:59:21 AM(UTC)
GE Washing Machine fills, and drains but does not Agitate/Spin (Washer Repair)
by Where's the EASY BUTTON 5/13/2013 5:37:42 PM(UTC)
GE washing machine does not agitate or spin (Washer Repair)
by SandieS 3/25/2013 4:11:01 PM(UTC)
GE washing machine will not fill (Washer Repair)
by ProjectMan 2/16/2013 8:51:00 AM(UTC)
ge washing machine (Washer Repair)
by pilotincmd 11/30/2012 6:44:07 PM(UTC)
GE Washing Machine not spinning consistently (Washer Repair)
by Rjr19146 11/5/2012 6:15:45 AM(UTC)
GE Washing Machine Agitates SLOW (Washer Repair)
by zappa_69001 5/14/2012 9:20:07 AM(UTC)
GE Washing machine problems (Washer Repair)
by Lisalynn782003 1/31/2012 10:40:29 AM(UTC)
Water will not stop filling on my GE Washing machine (Washer Repair)
by zepheadpat 1/30/2012 6:52:29 AM(UTC)
