2 Pages12>
joebrandom
#1 Posted : Sunday, December 9, 2012 3:12:39 PM(UTC)
joebrandom
My GE side by side will stop cooling and will not start up until I unplug it for at least 5 minutes and plug it back in. It may work fine for 3 to 10 days and it will stop cooling again. Repeating the above works to get it going again.
Any help out there?
#2 Posted : Monday, December 10, 2012 3:29:48 PM(UTC)
Hello,
Sounds like the problem is a bad main control board. In order to provide most accurate advice we need you to verify and repost the model number.
joebrandom
#3 Posted : Monday, December 10, 2012 6:47:53 PM(UTC)
joebrandom
Model #dss25jfpj ww
Serial #hh229716
#4 Posted : Monday, December 10, 2012 8:25:57 PM(UTC)
This model number does not come up anywhere. Is this refrigerator made to use in US?
joebrandom
#5 Posted : Tuesday, December 11, 2012 11:09:19 AM(UTC)
joebrandom
The serial number that you have is correct. This refrigerator has live in the US all of it's life. (what is left of it) It is not quite 5 years old.
#6 Posted : Tuesday, December 11, 2012 1:31:38 PM(UTC)
The second "J" in the model number DSS25JFPJ is incorrect. That means I can not get the correct part number for the main control board.
joebrandom
#7 Posted : Sunday, December 16, 2012 8:23:03 PM(UTC)
joebrandom
I checked the model number 3 times. It is what I sent you.
#8 Posted : Monday, December 17, 2012 10:35:42 AM(UTC)
Well, I've checked out all similar models and looks like they all have the same main control board.
- The main control board Part number: WR55X10942
joebrandom
#9 Posted : Monday, December 17, 2012 12:09:35 PM(UTC)
joebrandom
The label inside the refrigerator says......
General Electric Company
Appliance Park Louisville, KY
I checked the model number again and it is still the same...
#10 Posted : Monday, December 17, 2012 12:28:15 PM(UTC)
Open the control panel and check if there is an encoder (#424 at the diagram).
If there is such part, unplug it next time the refrigerator will stop cooling. If it will start right away then the problem is a bad encode board.
2 Pages12>
