my mothers dryer wont shut off, it just goes all the way around and around, signal on or off still does same thing,any cycle. help please.
Sounds like a set of timer contacts (BK/BU) are not opening so there is always power to the timer motor. See the attachment for the wiring diagram Unplug the unit. Set the timer to off. Measure across the BK/BU contacts on the timer. Should be infinite ohms. Be sure to disconnect the wires on one side of the contacts, this prevents you from reading an alternate/parallel circuit path. |
THIS FORUM IS DEAD!!!!!!! |
