kevgle4587
#1 Posted : Monday, November 19, 2012 11:57:21 AM(UTC)
kevgle4587
HI I have a kenmore gas dryer that does not work anymore. During sandy I got an electric surge into my house and now my dryer does not work. When i open the door the light inside the dryer turns on but nothing on the front panel works at all. What does it sound like it might be?
rickgburton
#2 Posted : Wednesday, November 21, 2012 8:56:31 PM(UTC)
rickgburton
Groups: Expert
Do any of the LED's on the control panel turn on? If not check all the wire connections and check for supply voltage at the control board. If the indicator lights do turn on check the door switch with an ohmmeter for continuity when the switch is pressed in.
kevgle4587
#3 Posted : Wednesday, November 21, 2012 9:12:40 PM(UTC)
kevgle4587
Yes none of the led come on. Am I wrong to assume there is power to the machine due to the fact the light bulb inside turns on when I open the door?
rickgburton
#4 Posted : Wednesday, November 21, 2012 11:35:46 PM(UTC)
rickgburton
Groups: Expert
Well, there's power to parts of the machine, so you need to figure out where you're losing it. Let's take the door switch for instance. There's three wires on the door switch. One wire is COMMON and is on the common terminal on the switch. The wire for the light is on the terminal marked NC or Normally Closed. That means power for the light can go from the COM to to the NC and the light is on. The wire for the start switch is on the terminal marked NO or Normally Open so power can't go to the start switch with the door open. Now we close the door. The part of the switch that was closed for the light, is now open, no light. and the part of the switch that was open, is now closed, power to start switch. Just because part of the switch is good (LIGHT) doesn't automatically mean the other part of the switch (START) is also good. Now do you get it?
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
GE Dryer wont start (Dryer Repair)
by bob35614 2/13/2017 4:21:03 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
maytag legacy dryer wont start (Dryer Repair)
by kennypkay 11/15/2015 2:02:45 PM(UTC)
Admiral Dryer wont start (Dryer Repair)
by chargitt 8/24/2015 1:25:34 PM(UTC)
kenmore dryer wont start (Dryer Repair)
by coindog1 7/26/2015 12:33:16 PM(UTC)
by antoine123 6/10/2015 5:23:52 PM(UTC)
dryer contol lock is locked -dryer wont start (Dryer Repair)
by k62254 5/29/2015 1:10:18 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
dryer wont start (Washer Repair)
by rangerleader63@gmail.com 9/4/2014 7:56:01 AM(UTC)
by mich01 9/1/2014 4:17:03 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
by cnrimgr1 2/17/2014 12:27:23 PM(UTC)
by Tom Kerr 2/2/2014 8:30:02 AM(UTC)
