Groups: APP Team
Hi. Call the sheriff. Tell them to release your husband. First switch the oven breaker off/on.If that doesn't help - open the control panel and check if there is 120VAC between the control board contacts P2-1 and P2-3. If you have the correct voltage and control board has no display - replace the board Part number: 8302994
I gave hubby a reprieve--at least long enough to go to work. LOL! How do you get to the control panel? My son is here as I type and he said he could check it.
Well-it seems when my son went to check the control panel--it decided to come back on. Not sure what to do now.
Groups: APP Team
