suzyscott
#1 Posted : Thursday, October 4, 2012 9:31:55 AM(UTC)
suzyscott
When my washer goes into the spin cycle it will drain and sounds like it is spinning but the tub holding the clothes is not spinning and I have soaked clothes. They are clean but still dripping wet. What may be the problem and can it be fixed.
Simon / APP Team
#2 Posted : Thursday, October 4, 2012 12:06:21 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the washer agitates.
If it's not - most likely there is bad motor coupling
Part number: 285753A
Post the results.
Simon.
suzyscott
#3 Posted : Thursday, October 4, 2012 3:58:34 PM(UTC)
suzyscott
It agitates fine and it drains out and sounds like it it spinning but the tub inside doesn't spin to get all the water out.
Simon / APP Team
#4 Posted : Thursday, October 4, 2012 4:20:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the agitator and check the drive block
Part number: 389140
Part number: 389140
If that is OK -replace the clutch Part number: 285785
Part number: 285785
Post the results.
Simon.
