lborough
#1 Posted : Wednesday, September 23, 2009 11:35:25 AM(UTC)
lborough
My dishwasher starts the cycle and goes through the whole cycle, but never drains. I used to be able to hear it kick in when it started draining, but this never happens now......what could possibly be wrong. I don't have a stopped up drain, already checked for that. Thanks.
#2 Posted : Wednesday, September 23, 2009 6:42:05 PM(UTC)
A Model Number may help others help you
On most GE's
Remove the kick plate.
On the left hand front side of the pump you will see a solenoid.
This is the wash/drain solenoid.
It should pull down when the unit is supposed to drain.
With the unit off see if you can activate it manually.
Note the solenoid only gets power for about 10 seconds and then the water pressure holds the flapper valve in the drain position till the machine is empty. The spring then returns the valve to the wash position.
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Maytag Dishwasher Thermal Cutoff keeps blowing (Dishwasher Repair)
by k_nov 1/16/2019 5:03:04 PM(UTC)
GE dishwasher not heating.... gdf620hgj2bb (Dishwasher Repair)
by Keeber 1/12/2019 8:32:51 AM(UTC)
Kenmore Dishwasher fills then drains (Dishwasher Repair)
by qkantaris 1/5/2019 8:39:01 PM(UTC)
Help! Whirlpool Dishwasher Quiet Partner IV (Dishwasher Repair)
by sgamet421 1/4/2019 1:51:31 PM(UTC)
GE GDF570SSF0SS Dishwasher Door Leak (Dishwasher Repair)
by Ericsd2 1/2/2019 2:17:44 PM(UTC)
GE Dishwasher model GLD4500R00BB (Dishwasher Repair)
by aliaugi 12/26/2018 5:51:27 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
Looking for a dishwasher panel template (Dishwasher Repair)
by cablvr 12/11/2018 12:01:03 PM(UTC)
Middle Arm not spinning Maytag dishwasher mdb4949sdm2 (Dishwasher Repair)
by NateS 11/29/2018 5:34:42 PM(UTC)
Dishwasher starts then stops (Dishwasher Repair)
by rkoerner 11/29/2018 11:47:14 AM(UTC)
GE Profile Dishwasher Control Module (Dishwasher Repair)
by merb 11/17/2018 4:33:33 PM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
dishwasher hangs in rinse cycle (Dishwasher Repair)
by REOC 11/11/2018 6:59:14 PM(UTC)
Bosh Dishwasher SHE3AR75UC/22 runs for 3 minutes, and then stops. (Dishwasher Repair)
by wcking 11/11/2018 10:57:57 AM(UTC)
