2 Pages12>
ggencar
#1 Posted : Monday, October 1, 2012 11:56:39 AM(UTC)
ggencar
I have gotten into test mode, display shows t01.
How do I run the test?
I pressed and held the start button and it beeped and displayed a 3
that is the correct code for this model number.
I have been unable to take the next step.
#2 Posted : Monday, October 1, 2012 4:49:12 PM(UTC)
Try to turn the select knob.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0WW Washer | AppliancePartsPros.com
ggencar
#3 Posted : Tuesday, October 2, 2012 4:27:04 AM(UTC)
ggencar
When I turn the select knob. The display shows, t14, t13, t12, t11, t10, t9, t, t7, t6, t5, t4, t3, t2. for each turn,
ggencar
#4 Posted : Tuesday, October 2, 2012 10:00:44 AM(UTC)
ggencar
I figured out how to do the diagnostic test.
When I run test 11, the spin test. The machine does not spin. Display shows a zero. The next step also does not spin and the display shows a zero.
Where do I go from here?
#5 Posted : Tuesday, October 2, 2012 11:22:01 AM(UTC)
What did it show for t2?
What was the original problem?
ggencar
#6 Posted : Wednesday, October 3, 2012 8:30:43 AM(UTC)
ggencar
Washer tumbles before filling with water. Afterwards, it doesn't tumble or spin.
t1 returns 00
t2 returns 00
T10, drains washer but doesn't tumble.
T11, doesn't spin at all and returns 0 for both tests.
#7 Posted : Wednesday, October 3, 2012 11:43:39 AM(UTC)
Each time the washer starts, a wake up routine should be initiated:
The door locks.
The wash basket briefly tumbles in both directions.
The door unlocks.
The door locks.
The fill cycle begins.
Did it do it?
If you did hear the click from the door lock, verify if the door was really locked.
ggencar
#8 Posted : Wednesday, October 3, 2012 12:06:38 PM(UTC)
ggencar
The door locks.
The door unlocks.
The door locks.
Did it do it?
Yes, it went through the start up sequence as you describe. I let the machine run full cycle in order to generate any applicable codes. It ran as I would have expected. It drained after the wash cycle and refilled for the rinse cycle. The only thing I can detect is that the basket doesn't tumble and/or spin when it should.
#9 Posted : Wednesday, October 3, 2012 12:28:20 PM(UTC)
Check the inverter and the motor as described in the attached files. Post the results.
File Attachment(s):
How to test and replace the inverter.doc (220kb) downloaded 12 time(s).
How to test and replace the motor assembly.doc (474kb) downloaded 4 time(s).
Service panel removal.doc (74kb) downloaded 2 time(s).
You cannot view/download attachments. Try to login or register.
ggencar
#10 Posted : Thursday, October 4, 2012 11:00:51 AM(UTC)
ggencar
Thanks for all your help. The plastic box only contains connectors so I am assuming that this is not the inverter. I assume the inverter is the metal box to the rear of the plastic box. It has two heat sinks on it. That box is humming when the drum should be turning.
GE washer spin cycle noise (Washer Repair)
by Tcmancan 11/30/2018 6:01:12 PM(UTC)
GE washer Knob/Bracket (Washer Repair)
by B.Robb 11/16/2018 7:59:03 AM(UTC)
Ge washer agitates, drains, sounds like it is trying to spin but doesn't (Washer Repair)
by juntjoo 8/20/2018 6:45:25 PM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 2:46:00 PM(UTC)
GE Washer lights allblinking (Washer Repair)
by DionJ 3/10/2018 9:47:07 AM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
GE washer refuses to Spin / Drain (Washer Repair)
by Ultimate2 9/18/2017 12:44:56 PM(UTC)
GE Washer repair (Washer Repair)
by jppablo4987 4/24/2017 11:40:39 AM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
How to reset computer on GE Washer Model GTWN5650F1 (Washer Repair)
by Bhargis 1/11/2017 3:22:14 PM(UTC)
GE washer won't stop filling, agitate or spin (Washer Repair)
by nmoreno24 10/14/2016 6:57:55 PM(UTC)
GE washer doesn't agitate or spin (Washer Repair)
by natestiles 8/25/2016 7:13:45 PM(UTC)
GE Washer - power button not working (Washer Repair)
by TerKow 8/10/2016 6:17:30 PM(UTC)
GE washer sounds like a freight train on spin cycle (Washer Repair)
by srbalsiger 7/30/2016 8:31:39 AM(UTC)
2 Pages12>
