i Have Tested The Ice Maker ( L & N ) To Verify I Have Power To Ice Maker. i Put A Jumper On T & H And The Motor Did Not Run So It Is Suggested I Replace The bimetal Thermostat Cycle? can You Give Me A Hint Where That Part Is Located? If That Is My Problem I Will Be Ordering The Part From You. Thanks For The Help. larry O'hern
