DoM1970%!$
#1 Posted : Monday, September 21, 2009 1:45:31 PM(UTC)
DoM1970%!$
Water level sensor quit working so that water in tub never stopped filling. Only looks like there is a plastic tube that hooks to tub and up to the water level switch. The tube looks fine and so I ordered and installed a new water level switch from your company. Works fine now except it will still occasionally not recognize the extra small setting and fills to a small level especially on initial wash after it has been not used for awhile or occasionally on the rinse cycle. Is there another part I'm not seeing or do I need to calibrate the new switch in some way when I installed it? Please help.
sidfink43
#2 Posted : Tuesday, September 22, 2009 5:56:34 PM(UTC)
sidfink43
Sounds like you have a defective switch. Those of us who volunteer to respond do not work for APP but my experience in buying parts from them is that they stand behind them, so if you have not had the part for a long time give them a call and see if you can get a warranty exchange.
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
by bigdanallan 1/20/2011 7:42:20 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
how do you test water level switch (Washer Repair)
by ldutton 10/11/2009 7:04:15 PM(UTC)
