Water level sensor quit working so that water in tub never stopped filling. Only looks like there is a plastic tube that hooks to tub and up to the water level switch. The tube looks fine and so I ordered and installed a new water level switch from your company. Works fine now except it will still occasionally not recognize the extra small setting and fills to a small level especially on initial wash after it has been not used for awhile or occasionally on the rinse cycle. Is there another part I'm not seeing or do I need to calibrate the new switch in some way when I installed it? Please help.
Sounds like you have a defective switch. Those of us who volunteer to respond do not work for APP but my experience in buying parts from them is that they stand behind them, so if you have not had the part for a long time give them a call and see if you can get a warranty exchange.
