WildmanWilson
#1 Posted : Sunday, September 20, 2009 12:34:26 PM(UTC)
WildmanWilson
Im not getting water to the ice maker but I am getting water at the water dispenser in the door. I took the leads off the dual solenoid to the water dispenser and swapped them with the one going to the ice maker. I can get water flow to the ice maker then when I push the water despenser. So it would seem the solenoid opens this way. So why isnt it filling with water if the solenoid opens. It seems whatever tells the solenoid to the icemaker to open isnt talking to it.....any ideas?
applianceman
#2 Posted : Sunday, September 20, 2009 4:05:47 PM(UTC)
applianceman
If you pull the ice ejector a little the icemaker will continue to cycle. If when you do that the water will run in the first thing to check is the feeler arm (the metal arm that turns the icemaker off when the ice bin fills). Make sure the arm will go completely down and if not the spring (#2 on your icemaker parts breakdown).
If the icemaker cycles but don’t run water one of the switches in the icemaker may be bad or you may have a loose connection.
If the icemaker fails to cycle the gears on the front of the icemaker may be broken. Hope this helps.
Refrigerator repair guide
frigidaire ice maker 241642503 not working (Refrigerator & Freezer Repair)
by jesus freak 8/1/2023 3:07:31 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Frigidaire Ice Maker Arm won't move (Refrigerator & Freezer Repair)
by Guest 7/10/2022 6:18:09 PM(UTC)
Frigidaire ice maker not working (Refrigerator & Freezer Repair)
by lilacreality 1/4/2016 1:38:29 PM(UTC)
Frigidaire Ice maker only making huge chunks (Refrigerator & Freezer Repair)
by WAKS 10/14/2015 6:46:20 PM(UTC)
frigidaire ice maker not working (Refrigerator & Freezer Repair)
by joeyjags 3/23/2015 10:39:43 AM(UTC)
Frigidaire Ice Maker Won't Turn Off (Refrigerator & Freezer Repair)
by Fathergoose007 9/7/2014 2:15:19 PM(UTC)
Frigidaire Ice Maker--making noise/not making ice (Refrigerator & Freezer Repair)
by lak 6/23/2013 3:03:35 PM(UTC)
Frigidaire Ice maker making ice very slow. (Refrigerator & Freezer Repair)
by Mrpaul88 7/27/2012 7:59:50 AM(UTC)
Frigidaire Ice Maker (Refrigerator & Freezer Repair)
by RSP3 12/23/2011 8:46:23 AM(UTC)
No water to Frigidaire ice maker. (Refrigerator & Freezer Repair)
by Ice Master 11/22/2011 8:59:04 AM(UTC)
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
Frigidaire ice maker control panel has no power (Refrigerator & Freezer Repair)
by F1USGP 2/20/2011 2:15:22 PM(UTC)
Frigidaire ice maker switch shut off arm won't go down to on (Refrigerator & Freezer Repair)
by lcapelis 4/9/2010 1:31:50 AM(UTC)
by luigys22 2/22/2010 6:25:14 AM(UTC)
