Situation: Freezer and fridge section both set at 9. Fridge temp OK. The following sequence has occured three times. Freezer section sticks in the defrost temperature range ~+10F. If turn off power for few minutes, then turn back on, the freezer section recovers and operates at -10F to -20F for about 10 days. Then the cycle repeats.
