boomerm
#1 Posted : Saturday, September 19, 2009 6:34:21 AM(UTC)
boomerm
Ihave a kitchenaid refrigerator that the control panel inside the door started flashing and the unit is beeping. I killed power to the unit but it continues to not operate. Any help would be apperciated
boomerm
#2 Posted : Saturday, September 19, 2009 8:06:28 AM(UTC)
boomerm
Upon further investigation, I found that both the condenser and evaporator fans are not working. I checked voltage to the fans and there is no voltage.I believe that the relay is not working but I am not sure where it is....
Dacor 36" range - Control Panel Flashing (Oven Repair (including Ranges and Cooktops))
by Matta0413 9/9/2019 4:31:45 AM(UTC)
Washer control panel flashing (Washer Repair)
by martyphee 11/2/2015 9:47:31 AM(UTC)
