botkes5
#1 Posted : Friday, September 18, 2009 6:04:19 PM(UTC)
botkes5
Model Number: KUDI01TJBL01 Brand: Kitchen Aid Age: 5 - 10 years
I first noticed that the front panel normal wash cycle push button would not stay lit. (green) After some numerous times pushing the button it did finally stay lit, the dishwasher would now start. Now it won't start at all. When I push any of the buttons on the panel they blink a few times then go off. ALL except the normal button it stays dark. I have the for (service technician's use only) paperwork from behind the kick panel. And I read the error message about the stuck keys. From what I read My keys are not stuck. I suspect the control panel works. I suspect it has something to do with the push buttons. So any help would greatly appreciated.
Senior Expert
APP Volunteer
You probably need a new control module AP3775964
I've replaced the control module as suggested and at least my buttons now work and don't flash when pushed. I've tested the overfill, door switch. Both tested good. The dishwaher works in the cancel/drain mode but not the fill mode. So I ordered a fill valve after testing that and that did not work either. The TCO in the wiring Diagram, is that the fuse that is attached to the cotrol module? (AP3178588). Any other help would be of great help.
#2 Posted : Saturday, September 19, 2009 12:55:18 AM(UTC)
Replacement parts for KUDI01TJBL01 models | AppliancePartsPros.com
The TCO in the wiring Diagram, is that the fuse that is attached to the control module?
Yes
Item 6 in the "Control panel" section
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Viking DDB325SS Dishwasher won't start (Dishwasher Repair)
by tmman 6/10/2020 6:44:15 AM(UTC)
Bosch dishwasher won't start after power surge (Dishwasher Repair)
by Larry120 7/17/2018 11:07:27 AM(UTC)
Bosch dishwasher won't start -- display flashes time (Dishwasher Repair)
by rsilk 6/28/2018 6:21:47 PM(UTC)
Dishwasher won't start when house is too cold (Dishwasher Repair)
by manshack_one 1/2/2018 8:13:29 AM(UTC)
dishwasher won't start (Dishwasher Repair)
by goosemasterkl 9/6/2017 5:03:10 PM(UTC)
Ge dishwasher won't start (Dishwasher Repair)
by gegerva 10/9/2016 5:45:31 AM(UTC)
GE dishwasher won't start (Dishwasher Repair)
by tyanbinh 6/10/2016 7:01:58 PM(UTC)
Dishwasher won't start cycle (Dishwasher Repair)
by fugue 4/16/2016 4:33:36 AM(UTC)
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
by Tricjabs 1/26/2016 5:41:06 PM(UTC)
by Strum310 11/15/2015 5:57:23 PM(UTC)
by dhbrittain 9/9/2015 3:35:11 PM(UTC)
