martin78
#1 Posted : Friday, September 18, 2009 8:10:06 AM(UTC)
martin78
Freezer door replacement parts for GE PTS25LHPARWW | AppliancePartsPros.com
Fresh food door replacement parts for GE PTS25LHPARWW | AppliancePartsPros.com
the door gaskets #23 and #24 are both leaking slightly. it looks like they are warped and allow air to flow through. I tried using a few small shims to push the gasket out but it isn’t working really well. Is there any thing else I can do to fix these gaskets instead of just buying them? some way to recondition them? anything else, as I don’t want to spend $150 on 2 gaskets?
martin78
#2 Posted : Saturday, September 19, 2009 5:14:00 PM(UTC)
martin78
nudge
nudge
#3 Posted : Sunday, September 20, 2009 2:16:49 AM(UTC)
I would raise the front feet to tilt the front of the refrigerator up a bit, straighten out the door gaskets and duck tape the doors shut overnight, should solve your problem.
Before doing this, make sure the bottom of the gaskets are not busted up with the magnetic strip falling out.
