AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer Problem during Spin Cycle, please advise
Washer tub has a lot of play in it. I can tilt it by hand from left to right and top to bottom. Washer is level, but it moves out of position during every spin cycle. Tub slams or bangs very loudly to a stop when spin cycle ends or machine is stopped during spin cycle. Which parts are needed to correct this problem. How many suspension springs does this model have? What type of lubricant should be used, if needed. Is WD-40 OK or is there a special lubricant I need to purchase.
Washer Repair
