kayrdee
#1 Posted : Tuesday, July 24, 2012 9:46:29 AM(UTC)
kayrdee
When I set the timer to any mode (regular, permanent press), the dryer makes small clicking sounds but when I push the "Start" button the dryer does not run at all. When I move the timer dial to the "finish guard" cycle, the motor and the drum run fine - most likely this cycle doesn't need any heat. The door switch is fine.
Could this be a timer switch issue or the thermal fuse issue? Appreciate any pointers.
-kd
Simon / APP Team
#2 Posted : Tuesday, July 24, 2012 12:09:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the timer Part number: 3392949
Post the results. Thank you.
Simon.
kayrdee
#3 Posted : Thursday, July 26, 2012 8:46:05 PM(UTC)
kayrdee
Simon,
Thanks a bunch for your help. I ordered the timer and replaced in 10 mins. Your diagnosis was correct - it was a bad timer. The dryer is back to normal.
Out of curiosity, I opened up the dead timer. Boy, it is full of copper reeds - age old mechanical stuff :eek: . No wonder they fail. I was thinking these timers would be electronic.
Simon / APP Team
#4 Posted : Friday, July 27, 2012 9:41:03 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
