Last night the washer stopped spinning.. it goes thru all the cycles- fills and drains. but the basket doesnt move.. therefore the clothes are very very wet.
Machine is more than 10 yrs old. Never have had a service call on it. Is this an inexpensive fix or should I start looking for new machine? I dont have problem fixing machine- if the cost will be quite a bit less than new machine.. Any suggestions?
Originally Posted by: applianceman  It says Kenmore- Heavy Duty 60 Series.. I bought it at Sears. I will have to go home to check more... dont know if this helps
Well Whirlpool makes most Kenmore washers but I hate to answer about Whirlpool and it turns out to be something else. We always need the model number especially on Kenmore. The model number should be near or in the lid.
Ok,
I found the model etc.. it said Model # 110. 92260100 Serial # CC0221372
Does that help?
